sum of hex / lrc check
Hi!
I have a string that i want to send trough serial to a device. The thing is, that before i send it, i have to make the LRC check. So, I have to sum the hex string parts. How can I do this?
For example, I have a string control and I write "#01SVT<BL>+098,0<CR><LF>". To make the LRC check i have to make the sum in hexadecimal, so I have to do this:
23+30+31+53+56+54+20+2B+30+39+38+2C+30 = 2C9
Message Edited by Luigi007 on 05-18-2006 05:46 PM
(5,827 Views)
See the zip file in this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=142841&requireLogin=False
There is a checksum vi inside the llb file in this thread that adds the array elements.
(5,806 Views)
Hi Luigi,
now I understand, where the number 2C9h comes from.
If you sum up the elements, the representation is an integer. This is a CPU- readable representation of a non- floating-point value. If you want to read this value too, it has to be converted into a decimal or hexadecimal representation. The decimal conversion is done by the numeric indicator, only that you can read it. If you need a hexadecimal string to send to the serial port, you have to convert the integer value to the string. the picture shows you, how to do it.
I hope, I helped you.
Greetings, Dave
Message Edited by daveTW on 05-19-2006 01:25 AM
Greets, Dave
(5,798 Views)
Thanks Dave .
(5,772 Views)
Hello, would you have a picture in False case, too?
(769 Views)
Hi JC,
You really want another image on an 18 year old example VI? Really?
Btw. it's a "default if unwired" tunnel in the case structure, so the other case is EMPTY...
(757 Views)
Thanks!
(747 Views)
