user event with no data
I am just starting out using custom user events.  It seems straightforward to create one, but it seems that the "Create User Event" block diagram object rather presumptiously assume that I must want to have some data associated with the event.  Sometimes one does, of course, but other times, it is sufficient to merely know that the event occured.
I think it's rather silly for me to create a bunch of dummy datatypes for events that don't require data.  Is there a way to do this?
Thanks.
(3,166 Views)
Personally, I use an event to stop my applications usually. When I register this stop event, I just use a boolean even though I never read that value of boolean.
You don't have to create a bunch of dummy datatypes, you can just use a boolean (or whatever you want) for them all.
Cheers
(3,165 Views)
Accepted by rothloup
You never know when you might want to pass data, or maybe pass more data than you already are.  So in my designs I usually have an empty variant as the default data, but have this variant be a type def.  That way in the future if I have some settings I want I can update the type def (that is a variant) with the real data I care about.  Or even pass data in the variant as variant attributes.  Maybe I want to tell my exit command to have a timeout on killing some other tasks, or maybe I want to tell my exit to do a taskkill, or who knows.  And if that variant attributes aren't there then just exit like normal.  My point is in the future I may want to send some kind of data along with the command to do stuff.
There have been times in the past when I throught "I'm never going to need to send any extra data".  Like one time I sent a command back to a caller VI to close a floating window, and insert it into a subpanel.  Then I realized I might want to send a command to pull the VI out of the subpanel and make it floating so I added a boolean.  True means pull it out, False means put it in.  Then I realized I may want to command the window a position and size to pull it out to.  Eventually I made it into a type def, but in this case I should have done this from the start.
(3,154 Views)
