write to measurement file resets to 1904
LV 2014
Windows 7 Professional
64 bit OS
The first run of this vi creates an excel file that is time stamped correctly.
The second and subsequent runs, the time stamp is reset to 1/1/1904 00:00:00.000.
When I click the state 1 button, the USB DAQ's measure temp and voltage. Some calculations happen.
The data is sent to state 2 via local variables.
Write to Meas File makes an excel file. Settings as shown in picture. In advanced settings in Write to Meas File, absolute time is checked.
Can you help me get back to the future?
vi saved as Main 2014 and 2013 respectively.
(4,845 Views)
Accepted by Carmen92126
Open up your Convert To Dynamic Data node.  You have it set to the time to be "Zero".  You want it to be set to "Now".
GCentral
(4,808 Views)
Thank you! That worked.
(4,797 Views)
no sir, even after implementing it i'm getting the same problem in the  .vi
what shall i do then.
here is my .vi shot
here is the dynamic data attributes that are been set
now please try to clear my quiries
(4,412 Views)
Hi triptathakur,
I believe your issue is coming from your "Write to Measurement File.vi". If you open up that express VI and click on 'Advanced..' in the bottom right corner, you should be able to select a check box "Absolute" to have your time be saved and displayed correctly.
(4,373 Views)
