LabWindows/CVI Idea Exchange
vix
Select the active configuration in the status bar
The active configuration (Debug, Release, custom ones, ...) is shown in the bottom-right corner of the status bar (see attached config01.jpg).
I think that it would be better if this would be a menu ring that can be used to change the active configuration, without having to select Build >> Configuration >> xxxx (see config02.jpg)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
1 Comment
LuisG
NI Employee (retired)
Status changed to: Under Consideration
