The active configuration (Debug, Release, custom ones, ...) is shown in the bottom-right corner of the status bar (see attached config01.jpg).
I think that it would be better if this would be a menu ring that can be used to change the active configuration, without having to select Build >> Configuration >> xxxx (see config02.jpg)
