With the batch built dialog, it is possible to select "all releases" and/or "all debugs". This button causes, that all 32-bit AND 64-bit releases and/or debugs are selected (marked). It would be helpful, if the selection buttons would be splitted in "select all 32-bit releases", "select all 64-bit releases", "select all 32-bit debugs" and "select all 64-bit debugs". When I develop e.g. 32-bit Software, I don't need the 64-bit versions.
It would be also helpful, if it is possible to select the sequence of the batch built. For example: project 1 depends on project 4, but project 4 is currently compiled after project 1 etc.
