LabWindows/CVI
Create and view PDF?
Hi
I've been reading about Haru PDF to generate a pdf.
Could someone please post an example for Labwindows\CVI? .Im not sure how to get it to work.
One other thing is how can i display the pdf without installing an external program?
Shako
Help share your knowlegde
Message 1 of 8
(3,944 Views)
I just saw muPDF.
does anyone know how can i use the in my program?
Message 2 of 8
(3,940 Views)
just a small note (didn't know haruPDF before...): I use fop (apache-java-tool) to create pdf-reports based on xmls and xsl, works quite nice.
Message 3 of 8
(3,936 Views)
Here you can find a sample project for report creation using the HARU Pdf library.
Message 4 of 8
(3,927 Views)
Thanks.
This shows me much more than what i was doing.
Do you know if there is a way to display a pdf in a CVI panel?
Message 5 of 8
(3,922 Views)
You can use an ActiveX container, but you must use the ActiveX interface of a PDF viewer (for example Adobe Reader).
The approach is similar to the WebBrowser example (or other ActiveX supplied samples)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 6 of 8
(3,911 Views)
i was think of that.
But need my program to be self contained.
Thats the reason why i used Haru for pdf creation.
Is there a way to convert a pdf to and image which i can display in cvi ?
Message 7 of 8
(3,908 Views)
Hi Shako,
Have you tried doing a quick Google search for a PDF to image converter? There seems to be lots of options on the web (some free, and some paid).  I don't know if I can recommend a specific one as I have never tried doing this before.
Hassan Atassi
Senior Group Manager, Digital Support
Message 8 of 8
(3,884 Views)
