02-25-2009 10:56 PM
How can i make customized combo box like attached file (Example.jpg) using CVI library?
The combobox in capture figure is made using MS tool.
I am a novice in programming as well as CVI. Please explain in detail if anyone knows.
02-26-2009 03:53 PM
You can do this, but it will require some programming. You cannot add columns to the ring control menu, so you'll have to create your own popup with a tree control that replaces the ring menu. I've attached an example program as a proof of concept and to get you started.
Hope this helps,
- jared
03-01-2009 05:53 PM
