LabWindows/CVI
How can put a splitter or second column in combobox using Labwindows/CVI?
How can i make customized combo box like attached file (Example.jpg) using CVI library?
The combobox in capture figure is made using MS tool.
I am a novice in programming as well as CVI. Please explain in detail if anyone knows.
(3,417 Views)
Accepted by yhkim
You can do this, but it will require some programming. You cannot add columns to the ring control menu, so you'll have to create your own popup with a tree control that replaces the ring menu. I've attached an example program as a proof of concept and to get you started.
Hope this helps,
- jared
(3,382 Views)
Really thanks a lot for your kind support. i'll try based on the program you made.
(3,360 Views)
