01-11-2008 06:41 PM
01-11-2008 11:18 PM
01-15-2008 01:33 PM
Okay, I'm attaching an updated file that hopefully no longer has any deadlocks.
To really fix these locking problems properly, a change will need to be made in CVI itself, which won't happen until the next version. But until that happens, you should be able to use this particular version of toolbox.c, which should work with existing CVI versions. Once the change in CVI is made, then CVI will install a version of toolbox.c that is different from this one, since at that point the locking can be made a lot simpler.
But please do let us know if you still see any bad behavior.
Luis
01-22-2008 11:58 AM
