02-16-2022 12:11 PM
I just installed LabWindows/CVI 2017 on a new laptop.
When I click the check box for 'Preview Substitutions' on the Version Info dialog panel, anywhere %company is comes up blank.
I have looked at C:\ProgramData\National Instruments\CVI2017\bin\userinfo.ini and the 'CompanyName' element is correctly set to my company.
Scratching my head.
02-16-2022 04:36 PM - edited 02-16-2022 04:37 PM
Hello John,
I had the same problem in the past and Luis helped me to correct it: see this post from him and the whole discussion it pertains to for reference.
02-17-2022 01:59 AM
Sorry, I just realized that the folder you looked into is the exact one I was pointing you to! Sorry, I cannot hep you more that this.
Sometime those info must have been moved elsewhere: while looking into it I realized that my userinfo.ini file located in that folder holds data that are not up to date and do not correspond to those shown on CVI splash screen.
02-17-2022 02:12 AM
Hi
You can check the following registry key:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments\CVI\17.0\User Info
Maybe the company name is picked from the CompanyName registry value?
Gaus
02-17-2022 03:33 AM
Try editing your ni.com profile and provide a company name there see if that works.
If you activate CVI with your ni.com entitlement, it is possible that Company is read from that entitlement.
02-21-2022 08:49 AM
Thank you, Gaus!
I tried the registry key that you indicated and the CompanyName element in the key was set correctly.
You pointed me in the right direction though.
In the registry I created the following key:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\CVI\User Info
Under this key I created the element 'CompanyName' and set this element to my company name.
This solved the problem.
