LabWindows/CVI
New Bug in CVI2013SP1?
I wonder if enabling/disabling "Embed UIR file into executable" setting makes any difference?
Normally, if enabled, changing the uir reqires a rebuild.
S. Eren BALCI
IMESTEK
Message 11 of 20
(2,875 Views)
Hi Eren,
I do have "Embed project .UIR's" enabled. However, if I change the UIR file, save it and only then press the green triangle there is no recompilation... but the executable shows the modified UI...
Message 12 of 20
(2,872 Views)
It is logical that it does not recompile. It should just add the new uir resource to the readily built binary.
The difference might be in the include file associated with the uir.
If the uir change requires a change in the header, the source files including that header have to be recompiled. Otherwise I think it is a simple appending operation to embed uir into exe.
Maybe if you save it first, it can realize if the change effect the header or not. If you run it directly, maybe it rewrites the header anyway and therefor recompiles the files including that header.
Can you try making a more radical change, like changing the tab order (this causes the IDs to change) and save by clicking the toolbar.
The source files that include the header should get marked for compilation.
S. Eren BALCI
IMESTEK
Message 13 of 20
(2,866 Views)
Hi Eren, thanks...
I have tried your suggestion and you were right: adding a new control, for example, forces a compilation in both cases (as expected).
So my initial question remains why the two approaches to compile a project after a 'small' change of the UIR behave differently, or, as Eren called it, why is pressing the Save disk icon smarter... in my opinion both user actions should yield the same program action
"Maybe if..." It would be nice to hear from NI what actually is happening so that we don't have to guess
Message 14 of 20
(2,853 Views)
Hello Wolfgang,
Eren is right. When saving the *uir the associated header file is not modified if not necessary. But if you click Run without saving the file the header file is re-written. You can see this if you look at the timestamp of the h file.
I think what this dialog displays: "Saving them will cause CVI to generate new versions of their associated include files." wants to suggest this behaviour but I'm not sure.
Why are you saying this is a new bug in CVI2013SP1? I can see the same behavour in the earlier versions.
Constantin
Message 15 of 20
(2,842 Views)
@Constantin--P wrote:
Hello Wolfgang,
Thanks Constantin for confirmation!
The reason I called this behavior new simply was that I did not remember to have seen this before Smiley Wink
Message 16 of 20
(2,839 Views)
My focus was not so much on the 'new' 😉
So Constantin, would you agree that this behaviour is 'counter-intuitive' and deserves a CAR?
Message 17 of 20
(2,813 Views)
Accepted by Wolfgang
Hello Wolfgang,
The CAR number is 464163.
Have a nice day,
Constantin
Message 18 of 20
(2,808 Views)
Thanks!
Message 19 of 20
(2,803 Views)
fixed in CVI 2020
Message 20 of 20
(1,226 Views)
