LabWindows/CVI
Receive CAN messages in a new thread pool
Hi, I use a thread to receive CAN msg like code below:
int CVICALLBACK DataAcqThreadFunction (void *functionData);
int main(int argc, char *argv[])
    int panelHandle;
    int functionId;
        DisplayPanel (panelHandle);
    CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE, DataAcqThreadFunction, NULL, &functionId);
    RunUserInterface ();
    DiscardPanel (panelHandle);
    return 0;
    while (!quit) {
        ncWaitForState(...)
    return 0;
the code works fine but i need to close the thread, unfortunately the thread is locked in ncWaitforstate so i can not terminate it until i receive at least one msg.
Have you some idea to implement a receive method in a new thread without polling type?
thanks
marco
(2,831 Views)
Can you not use the timeout facility of the ncWaitForState() function to allow for a termination to be handled more cleanly? At least it would prevent the thread from becoming locked in the function.
JR
(2,827 Views)
I need a thread that stays always in listening mode to catch any kind of msg. In fact, i use ncWaitForState(panelHandle, NC_ST_READ_AVAIL, NC_DURATION_INFINITE,0)
marco
(2,824 Views)
