LabWindows/CVI
Select multiple controls with the mouse in CVI programming
I have generated a lot of controls in the panel. Now want to select some specified controls using the mouse, and hope using it drag a reactangle to cover what selecting controls. Please advise if can realize the behaver?
David
(4,101 Views)
I am assuming you mean that you want to do this in the UIR editor. If so, here is how you do it:
Hold down the shift key on the keyboard. Click the mouse button and drag a selection box around the controls you want.
Or you can hold the shift key and click on each control you want selected. To remove a control from the selection group, hold down the shift key and click the control again.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(4,095 Views)
Yes. But I just want to use the mouse, not with the key to make a selection box, do you have any idea?
David
(4,089 Views)
Maybe I'm missing something...
On my machine I actually can draw a selection box with the mouse only: no need to use shift key for the first selection box. Using shift+drag-and-drop permits me to create a second selection box adding surrounded controls to the ones already selected.
What's exactly your problem, David?
(4,083 Views)
No Roberto, you are right, I was actually thinking about another application where the shift key must be held down.
However, that only applies to the initial selection of an area, after that if you want to add or remove controls to/from that initial selection box, you must use the shift key.
Martin Fredrickson
Test Engineer
Northrop Grumman
San Diego, CA 92128
(4,073 Views)
Hi Roberto,
How to draw a rectangle with the mouse in the panel to simulate the cvi panel edit mode?
David
(3,317 Views)
You would have to put a canvas control spanning the entire area of the panel, overlapped by all the other controls. Then, you'd have to catch the mouse click events and mouse move events and draw lines in the canvas connecting the current mouse position with the previous mouse position. Or something like that.
Luis
(3,290 Views)
