10-25-2007
02:25 PM
- last edited on
06-14-2024
11:43 AM
by
Content Cleaner
Hi Nati,
I'd like to take this back to the basics. I think we're missing something here.
1. Can you reliably control the Digital I/O with MAX?
This troubleshooting step is critical. If we cannot use the USB-6501 with MAX control then any programming language will have a problem using the USB-6501.
2. Remove DAQmx Base from the computer.
The operating system is Win XP, the driver of choice is DAQmx.
3. If the USB-6501 errors after removing DAQmx Base from the computer then the firmware is set to DAQmx Base, not DAQmx.
4. If the USB-6501 is working reliably through MAX then try our example programs.
Please let me know the outcome to step 1, this is the critical item.
MatthewW
Applications Engineer
09:39 AM
- last edited on
06-14-2024
11:43 AM
by
Content Cleaner
10-30-2007 10:09 AM
11-05-2007 06:46 AM
Hi MatthewW ,
So far so good no problems sinse i removed from the pc max base
Nati
11-20-2007
09:43 AM
- last edited on
06-14-2024
11:47 AM
by
Content Cleaner
Hi all --
Just to clarify a earlier point, I mis-stated that Windows XP should use DAQmx Base. That is not correct!
When using Windows XP or Linux then use DAQmx.
If using Mac OS X then use DAQmx Base.
I hope this hasn't caused any confusion.
MatthewW
04-01-2008 08:45 AM
Hello Nati.
Try to connect all devices from your system to a power supply which filters the peaks in the electric network (UPS with filters). I have suspicion that this is the cause. (Try to switch on some heavy motor in the vicinity, e.g. vacuum cleaner or lathe ( my case 🙂 )
Glidko.
04-02-2008 02:16 AM
05-14-2008 09:17 PM
05-15-2008 12:26 AM
I will try that
02-28-2013 06:48 AM
Hi
I get the same problem with 6501s.
Now with two different Windows 7 systems. I also can get the 6501 to hang on my laptop in MAX by simply clicking selftest a number of times on the test panel.
An earlier version of MAX lead to a Blue Screen Of Death when the DAQmx reset function hung via the 6501.
I've tried powered and unpowered hubs, diferent cables and even USB over CAT5 as the distance from the PC is 1.5 Meters.
I've found no real answers.
Mike Boyd
