LabWindows/CVI
USB 6501 card(s) becomes unresponsive
 Hi Nati,
 I'd like to take this back to the basics. I think we're missing something here.
 1. Can you reliably control the Digital I/O with MAX?
  This troubleshooting step is critical. If we cannot use the USB-6501 with MAX control then any programming language will have a problem using the USB-6501.
 2. Remove DAQmx Base from the computer.
 The operating system is Win XP, the driver of choice is DAQmx.
 3. If the USB-6501 errors after removing DAQmx Base from the computer then the firmware is set to DAQmx Base, not DAQmx.
 4. If the USB-6501 is working reliably through MAX then try our example programs.
 Please let me know the outcome to step 1, this is the critical item.
MatthewW
Message 11 of 21
(3,038 Views)
 Hi MatthewW,
Ans:
Yes, I can see and control the device from Measurement & Automation >> NI Daqmax devices
Ans:
Done, I removed DAQmx Base from the computer
Ans:
No Error after remove
Ans:
Can you give a a link to one of the example programs?
Nati
Message 12 of 21
(3,026 Views)
 Hi Nati,
 The example programs I was thinking can be found here:
  Run LabVIEW
  Click Help
  Click NI Example Finder
  Hardware Input/Output->DAQmx->Digital Generation-> Write Dig Chan or Write Dig Port.
 Give those a try, please let me know the outcome.
 MatthewW
Message 13 of 21
(3,006 Views)
Hi MatthewW ,
So far so good no problems sinse i removed from the pc max base
 Nati
Message 14 of 21
(2,981 Views)
 Hi all --
 Just to clarify a earlier point, I mis-stated that Windows XP should use DAQmx Base. That is not correct!
 When using Windows XP or Linux then use DAQmx.
 If using Mac OS X then use DAQmx Base.
 I hope this hasn't caused any confusion.
MatthewW
Message 15 of 21
(2,902 Views)
Hello Nati.
Try to connect all devices from your system to a power supply which filters the peaks in the electric network (UPS with filters). I have suspicion that this is the cause. (Try to switch on some heavy motor in the vicinity, e.g. vacuum cleaner or lathe ( my case 🙂 )
Glidko.
Message 16 of 21
(2,648 Views)
Message 17 of 21
(2,623 Views)
I had a similar problem with 2 USB 9472 devices hooked into a 4 port powered USB hub from linksys.  I finally narrowed it down to the usb cable between the hub and the computer.  For some reason when I switched to a brand new usb cable everything worked fine.
Message 18 of 21
(2,469 Views)
I will try that
Message 19 of 21
(2,467 Views)
Hi
I get the same problem with 6501s.
Now with two different Windows 7 systems. I also can get the 6501 to hang on my laptop in MAX by simply clicking selftest a number of times on the test panel.
An earlier version of MAX lead to a Blue Screen Of Death when the DAQmx reset function hung via the 6501.
I've tried powered and unpowered hubs, diferent cables and even USB over CAT5 as the distance from the PC is 1.5 Meters.
I've found no real answers.
Mike Boyd
Message 20 of 21
(1,677 Views)
