LabWindows/CVI
Windows 11 : blue screen after installing
I maintain a labwindows/CVI application which manages data acquisition with the USB-6210 box.
This application works perfectly under Windows 10 but the deployment of this application on Windows 11 PCs is very erratic.
On some Windows 11 PCs when rebooting I have a blue screen while on other Windows 11 PCs I have no problem.
Any idea?
(407 Views)
Any idea?
If the Win11 PCs uses ARM based CPUs, those are not supported and could lead to BSOD.
Santhosh
Soliton Technologies
(384 Views)
That is not the case. I have the problem on a Dell Latitude 5550 with an Intel Core Ultra 7 processor which is a x86 processor.
(379 Views)
I had the same issue on laptops with the same hardware. Thanks to the post below, I upgraded the PXI Platform Services Runtime to the latest one (from 2020 to 2024 Q4) which fixed the blue screen problem.
https://forums.ni.com/t5/LabVIEW/BSOD-nipcibrd-sys-SECURE-PCI-CONFIG-SPACE-ACCESS-VIOLATION/m-p/4381...
Does this solution work for you ?
Even if the blue screen error is fixes, I now have an error during the setup of my application :
The "NI VC2008 RTE x64" installation has failed with the following error : An error occurred during the installation of assembly 'policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.5054",public KeyToken="1fc8b3b9a1e18e3b",processorArchitecture"amd64",type="win32-policy". Please refer to Help and Support for more information. HRESILT: 0x80070091.
The same message appear with 'NI VC2008RTE x86'.
Any ideas ?
(371 Views)
I updated my setup to use the latest versions of the runtimes like you. I went from runTime 2020 to versions 2024.
Now I also have an error message during installation. Despite this, my application seems to work but it is not comfortable.
(365 Views)
