04-27-2011 07:08 AM
Hello NI,
in my understanding (and backed by Wikipedia and Wolfram ) the documentation of the incomplete gamma functions in CVI is wrong:
the incomplete gamma function and the complementary incomplete gamma functions must not include the factor
1/Γ(x);
at present the help file describes the regularized (normalized) incomplete gamma functions...
... I am going to find out what the function actually is calculating...
Solved! Go to Solution.
04-27-2011 09:27 AM
It turns out that GammaC actually is calculating the regularized incomplete Gamma function - hence while the formula in the documentation correctly describes the function, the function name and the textual description are wrong - the incomplete Gamma function and the regularized incomplete Gamma functions are two different things!
07-03-2012 05:47 AM
Since this comment passed unheeded for more than a year I doubt that the documentation will be corrected soon.
Anyway, for anyone using the Advanced Analysis Library please note that the same is true for the Beta function Beta (x, y, &z), which actually calculates the regularized incomplete beta function. It's not a big deal as it can be corrected using Beta ( x, y, &z ) * Beta ( x, y, NULL ) instead, but still, I would consider the help as in need of improvement...
07-03-2012 11:22 AM
Thanks for bringing this to our attention. You can track this with Bug ID 362123. All three functions are reported under the same ID. I did a quick look through the other functions in the library and did not see any others with the same problem. Let me know if I need to add any other functions to this bug report.
02-03-2015 04:10 PM - edited 02-03-2015 04:11 PM
What is the official status about this incorrect documentation (or at least denomination of these functions)?
We are approaching the 4 year mark and this has been left untouched.
EDIT: I am actually referring to the LabVIEW counterpart of these functions, so I will move this to the proper forum...
