LabWindows/CVI
define contents of menu bar from text file
I would like to list the contents of the menu bar dynamically by reading it from a text file. Is there a way to do this?
Thanks!
Sinnas
(4,320 Views)
I suppose you can do it by using InstallMenuDimmerCallback () function: this command installs a function that is called by the system before the menu is shown so that you can dim / undim the appropriate menu items depending on the execution state. See this tip of mine and the following commend from LuisG
This is the original purpose: you could customize the menu bar instead by using SetMenuBarAttribute () to change the item name(s) and event the associated callback function. I have never used this function that way, though, so I cannot tell you how efficent the mechanism can be and how much delay will it introduce before the menu is shown.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(4,319 Views)
In addition to what Roberto mentioned I'd like to point you to the ini-instrument driver which allows to conveniently read (formatted) text files, see also the example ini.cws that ships with CVI
(4,308 Views)
Thank you Roberto and Wolfgang. I will give your suggestions a shot and get back to you.
(4,305 Views)
Hi again.. I went through your suggestions but dont see them as solving my problem. What i want to do is add child items to my menu dynamically. For example at the moment my menu has 4 parent items and one of the parents has 3 child items. I would like to define these 3 child items through my text file. For instance if my text file has 4 sections then the parent will have 4 child items (inplace of the present 3).
Is something like this possible?
Thanks!
Sinnas
(4,297 Views)
Accepted by sinnas
Yes, it's possible. Have a look at the commands NewMenu and NewSubMenu... (and the overview here). There is also an example (UIRView)
(4,295 Views)
Oh yes perfect! just what i was looking for. Thank you wolfgang.
(4,290 Views)
