LabWindows/CVI
define contents of menu bar from text file
I would like to list the contents of the menu bar dynamically by reading it from a text file. Is there a way to do this?
Thanks!
Sinnas
(4,316 Views)
I suppose you can do it by using InstallMenuDimmerCallback () function: this command installs a function that is called by the system before the menu is shown so that you can dim / undim the appropriate menu items depending on the execution state. See this tip of mine and the following commend from LuisG
This is the original purpose: you could customize the menu bar instead by using SetMenuBarAttribute () to change the item name(s) and event the associated callback function. I have never used this function that way, though, so I cannot tell you how efficent the mechanism can be and how much delay will it introduce before the menu is shown.
(4,315 Views)
In addition to what Roberto mentioned I'd like to point you to the ini-instrument driver which allows to conveniently read (formatted) text files, see also the example ini.cws that ships with CVI
(4,304 Views)
Thank you Roberto and Wolfgang. I will give your suggestions a shot and get back to you.
(4,301 Views)
Hi again.. I went through your suggestions but dont see them as solving my problem. What i want to do is add child items to my menu dynamically. For example at the moment my menu has 4 parent items and one of the parents has 3 child items. I would like to define these 3 child items through my text file. For instance if my text file has 4 sections then the parent will have 4 child items (inplace of the present 3).
Is something like this possible?
Thanks!
Sinnas
(4,293 Views)
Accepted by topic author sinnas
Yes, it's possible. Have a look at the commands NewMenu and NewSubMenu... (and the overview here). There is also an example (UIRView)
(4,291 Views)
Oh yes perfect! just what i was looking for. Thank you wolfgang.
(4,286 Views)
