LabWindows/CVI
windows folder popup
I would like to launch a folder popup from my CVI code.
I tried using LaunchExecutableEx("c:\\data"), but that does not work. Does anyone know how to make a folder popup?
(3,218 Views)
Accepted by Steve_Block
Hi Steve,
Try  LaunchExecutableEx ("explorer.exe /select, \"c:\\data\"")
To make it enter into the "data" folder you have to write a file's path in c:\data.
So it will be something like  LaunchExecutableEx ("explorer.exe /select, \"c:\\data\\volts.txt\"")
I know this method because I use it as a custom tool in CVI Tools menu.
Maybe there is a way of opening the folder without specifying a file name, but I do not know that.
Hope this helps,
Note to the webmaster: I am sick of these paranthesis turning into smileys. Grrr..!
Message Edited by ebalci on 03-12-2009 09:52 PM
S. Eren BALCI
IMESTEK
(3,217 Views)
You could also consider using the toolslib File browser, a custom control build on top of a tree control, which has the advantage that you can insert it in a CVI panel instead of opening a separate window. The file browser, as all custom controls shipped with CVI, can be inserted in a CVI panel by right clicking on the panel and selecting Custom controls >> Toolslib controls >> File browser
(3,193 Views)
