02-14-2013 04:48 AM
guys can anybody help me out....plz
while making .exe application and Installer of a project with Labview...using ADV(Advision Toolkit) there is a error of missing variuos functions like ADVisionFIM.lvlib, ADVisionOCV.lvlib, ADVision OCV Dilate.vi, ADV Erode.vi...etc...
02-15-2013 03:54 PM
Do you have these libraries specified in project dependencies ?
08-17-2013 09:24 PM
hello sir! i just want to ask something. i download and istall the ADV Toolkit on my Labview. i follow your example to first run example 00. Check Your GPU Card.
but when i run it, the LED doesn't turn on. so for the conclusion I can't use the ADV Toolkit? is there any other toolkit that i can use for capturing images in
a webcam or in a built in cam? By the way my Laptop is Aspire One 722. I Hope for your immediate response. Thank you sir!
08-18-2013 05:12 AM
i download and install the ADV Toolkit on my Labview. i follow your example to first run example 00. Check Your GPU Card.
but when i run it, the LED doesn't turn on. so for the conclusion I can't use the ADV Toolkit? is there any other toolkit that i can use for capturing images ina webcam or in a built in cam? By the way my Laptop is Aspire One 722.
Yes, you can use it - GPU part and cam capture part are independent. Your notebook equipped with AMD Radeon HD video card, which is not supported by CUDA - therefore GPU part will not work.
But acquisition part should work if your cam is supported by OpenCV. Try "00.Grab Example.vi" for check if your cam supported or not.
08-19-2013 03:38 AM
hello sir it is me again. thank you for answering my first question. i try what you told me sir i try the example "00.Grab Image" but all i can see is a black image.
so this means that my camera is not supported right sir?
-thank you sir! 😄
08-19-2013 08:23 AM
hello again sir. i found an example that suites my laptop camera. i'll attatch it here. but i have a problem. the image that appears in labview is dark i mean the image
apppears by using the built in camera only, it does not uses some of its function. and can i also ask how to capture image? there are no examples in the labview. the examples in some forums i found has only a black image too. Tnx sir! hoping for your reply.
"Grab Express" example sir
01-28-2014 06:44 AM
can this toolkit build a facial recognition software?
12-20-2014 11:16 PM - edited 12-20-2014 11:19 PM
I have the same problem when build into exe file. The data folder has ADVisNPP.dll, ADVisOcv.dll, ADVisSvc.dll. I used Win 7 32-bit OS and LabVIEW 2014. Does it support? Thank you!
09-09-2015 05:41 AM
I would like to try this toolkit with labview and vision 2011 (and maybe later 2015), but all the links to download it are dead.
I can't find it elsewhere on internet neither.
Can you help me on this please ?
Thank you.
Nico
10-26-2016 09:02 PM
Try the way back machine
https://web.archive.org/web/20141114011224/http://www.vi-lib.com/
The latest version is 1.2.6
I still cannot make the capture working, but the rest of the toolkit is working.
Benoit
