12-03-2018 09:37 PM
Hello all,
I have a simple set up where my Basler acA2440-35um camera is hooked up to my PC with a USB3 wire and to my lighting controllers with a 6pin GPIO wire. Using VBAI, I'm able to trigger the lighting/camera acquisition as needed by using the read/write camera attributes option and I have no trouble with the checking.
However, upon PC start up, the lights are always switched on and will only be reset if I start up VBAI and run one instance of the checks. I believe the camera output lines are opened every time the PC is started up and that running the program basically resets the settings to what I want.
Is there anyway to stop the camera settings from being reset every time I shut down the PC?
Apologies if this has been posted on the forums before.
12-14-2018 05:09 AM
may be you have to switch off llighting/camera acquisition after use in VBA before closing the program .
