06-18-2013 12:19 PM
Any idea why this happens ??
Why does this error occur ?
06-18-2013 01:13 PM
What inputs have you wired to the VI? I suspect you are getting the error beause you are not providing the right path or you are writing into a directory that is restricted.
11-06-2018 05:12 AM
I also got the same error and i gave the file path but, Images are not saving in given file path.
can you please give me the solution for this ?
thanks in advance.
