Machine Vision
Error 1074395995 occurred at IMAQ WriteJPEGFile
Any idea why this happens ??
Why does this error occur ?
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
(5,952 Views)
Accepted by abikutn
What inputs have you wired to the VI? I suspect you are getting the error beause you are not providing the right path or you are writing into a directory that is restricted.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(5,947 Views)
I also got the same error and i gave the file path but, Images are not saving in given file path.
can you please give me the solution for this ?
thanks in advance.
(2,968 Views)
