02-04-2022 01:57 AM
Hi all,
Does anyone know if it is possible to change the rate IMAQdx sends "discovery ping" to network adapters to discover GigE cameras?
I don't need to turn this completely off, just reduce the flood of messages in the network.
Morso
02-04-2022 06:47 AM
Answering my own question.
Following the guide for disabling the "Discovery ping" but setting the value to some desired value other than "0" will change the pinging rate.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YR4ICAW&l=fi-FI
Morso
02-04-2022 07:37 AM
Pure curiosity : why would you like to change or remove this GigE ping ?
Anyway thank you for the question and answer it is interesting.
Sami
