Machine Vision
How to measure Dimension Object
how to measure and know the dimensions of an object using Labview 2014 and Vision Asisstant? The size of objects to be detected using a webcam? what pattern matching method can be used to know the size of the object to be detected?
thanks
(3,896 Views)
Use Imaq GetImageSize (X and Y resolution) to find the Image Dimension
(3,871 Views)
Can using Image Vision Assistant to detect Dimension object ? Calibration or Coordinate for Dimension?
But how to solution get Shape Detection of object ? and I want to ask ,can 1 input for 2 process image vision ,if 1 process to shape detection and 1 more process again for detect dimension or color object ?
Thankyou
(3,816 Views)
Riwan,
Please take a look at this getting started guide: http://www.ni.com/pdf/manuals/372228m.pdf
(3,804 Views)
