Machine Vision
NI Measurement & Automation Explorer 5.0 (higher version already installed)
I have downloaded NI-DAQmx 9.4, but when I attempt to install it I get the message:
Cannot install
o NI Measurement & Automation Explorer 5.0 (higher version already installed)
What does this mean? I have LabVIEW 2012 (Windows), version 12.0, 64 bit.
Neil
(5,052 Views)
Accepted by nbf
I think what's happening is that DAQmx is being installed properly but the installer is also trying to install an older version of Measurement & Automation Explorer (MAX), which is what is causing the error.
You can verify that DAQmx was installed properly by opening up MAX and checking to see if it's listed under the Software tab on the left.
One thing to keep in mind is that DAQmx 9.4 is not compatible with LabVIEW 2012, so you may just want to upgrade to the latest version of DAQmx, which is 9.6 and is compatible with LabVIEW 2012.
(5,048 Views)
I have a problem in uninstall labview and reinstall it. I could not found any National instrument icon in control panel and in the program file, i had delete all the antional instrument file using unloker. Now when i want to reinstall it, it show this error. What should i do ?
(3,327 Views)
Hi baoxuan,
Here is a helpful link in uninstalling NI Software: Uninstall National Instruments Software
Also this is a 6 year old, solved thread so not many users will see this. To get better visibility, I would suggest creating a new thread.
All the Best,
Noah B.
Applications Engineer
Noah B.
Technical Support Engineering
(3,317 Views)
Thank you !
(3,301 Views)
