I hope someone could help me.
I have a production PC where I would like to start an inspection programmatically from the command line e.g. "C:\Program Files (x86)\National Instruments\Vision Builder AI 2018\Vision Builder.exe" \inspect "D:\VBAIs\test.vbai" \nowelcomeonexit
The inspection contains TCP steps. The problem is that the VisionBuilder TCP server is not starting in this case (tried to telnet localhost port) and inspection interface enters in some strange loop...
However, If I start manually the vision builder configuration interface and load the vbai manually, then switch to the inspection interface, everything works fine.
I would like to mention that this happens only on this particular PC. It would be time consuming to make a fresh install and replace the PC so I would like to ask if there is a method to debug this behavior.
Thank you guys in advance,
tippi
RO
