03-01-2022 03:07 PM
Hi trying to create Labview code from vision assistant. When I click on create labview code it tries to find nirio_FindDevice which it cannot and I searched for it and I don't have it on my machine. So, I can't create vis from vision assistant. I tried downloading the Compact RIO drivers since I saw that helped somebody else, but not me. - thanks
03-01-2022 06:43 PM
You are welcome to post your .SCR or .VSCR file, and I can run it though my system to see if it will build an VI.
It's not a long-term solution but might be informative.
I often generate LV code from VA.. Usually as snippets for insertion into a larger program.
cheers
Robert
03-02-2022 12:03 PM
Thank you, Robert. Turns out I had to update the common vision software with NI Package manager and it now works!
03-02-2022 12:06 PM
LOL.. Glad you solved it!!
