04-25-2005 11:29 PM
04-27-2005 05:05 PM
04-28-2005 02:58 AM
04-28-2005 05:51 PM
04-29-2005 12:49 PM
05-01-2005 07:41 PM
05-02-2005 11:03 PM
05-03-2005 09:10 AM
08-22-2017 09:08 AM
HI YR MEMBER, I also have this ImgSessionconfigure problem which takes a long time to configue, like 800-1000ms. It`s said that you have solved this problem in c/c++. can you detail your solution, since I can not found a suitable way to do it.
08-22-2017 02:12 PM
What version of IMAQ are you using? There were some improvements made to the speed of the Configure function a while ago that may help quite a bit if you are coming from an older version.
