05-09-2022 09:08 AM
Hi everyone,
I have a system based on LabVIEW Real Time 10.0f2 with a PCI-7354 built in 2009, running until last week.
Now the controller stops working at the initialization of the four axis. We replaced everything after the PCI-7354, axis, cables etc. It seems the PCI-card is broken.
I have a working replacement here from another system. If I swap the cards I got an error 70012 "Motion: Illegal board ID. You must use the board ID assigned to your controller in Measurement & Automation Explorer."
Is there any way to use the replacement card without rebuilding the operating system?
I don't have experience with Labview at all and it seems we don't have all the sources/software to rebuild the operating system
Best
Sven
05-09-2022 10:06 AM
Launch "Measurement And Automation Explorer" and change the board ID according to the Motion configuration.
05-11-2022 02:17 AM
Good morning, thank you for your reply.
Thank you for the hint to MAX. But why is the PCI-7354 not visible at devices? It looks the same for the broken system and for two working systems with same configuration. (PCI-6733 + PCI-7354)
Best
Sven
