DAQ analog inputs: is it faster to use single task with multiple channels (two to be exact) instead of two distinct tasks for 2 different channels?
They are the same data type: voltage, and are on the same board with same max and min values etc. How much of a time overhead do these tasks generally incur?
Aditi
(4,509 Views)
Since you simply can't use two different tasks at the same time, your question does not make much sense.
(4,493 Views)
I have previously used created and run two tasks at the same time but I realize now that they were probably not running "simultaneously". However My program seemed to work oK. Do you think this was because the timescales that I was updating the measurements were in 100s of milliseconds and the time that was spent switching between tasks was too small to notice?
(4,469 Views)
1 Sample On Demand?  That would probably work.  But I would say you just got lucky.  You would be much better off using a single task to read both channels.  It is just more efficient in many ways.
GCentral
(4,456 Views)
