'DAQmx Configure Logging' not found in Labview 2009
Dear Sir or Madam
I have Labview version 9.0f3 instored. Measurement & Automation Explorer version 4.60f1 instored.
Do I need to update anything to run the attached VI?
Problem:
As mentioned in the file as follows http://zone.ni.com/devzone/cda/tut/p/id/9574
'NI-DAQmx 9.0 installs a new VI, DAQmx Configure Logging VI'. However I can not find this VI in my control panel and the icon shows as a question mark.
(3,200 Views)
You are correct that DAQmx 9.0 and later includes the VI.  Which version of DAQmx do you have installed?
Here is a link to version 9.2.1.
Best Regards,
John Passiak
(3,195 Views)
Thank you.
All I know is that I have Labview version 9.0f3 instored. Measurement & Automation Explorer version 4.60f1 instored.
How to check the version of DAQmx? Does 'DAQmx' means 'Measurement & Automation Explorer'?
Regards
(3,193 Views)
Accepted by NCLbingji
There are a couple of ways to check your version of DAQmx:
1) Through Measurement and Automation Explorer:
2)  Through Add Remove Programs
My guess is that you are using DAQmx 8.9.5 and will need to upgrade to 9.0 or later.
Best Regards,
John Passiak
(3,187 Views)
You are absolutely right that I am using the DAQmx 8.9.5 at the moment. Thank you
(3,184 Views)
