Data acquisition using cRIO-9066 and C++
Hi there!
I want to write a C++ application which would acquire data from some modules installed in cRIO-9066 chassis and this application have to work without LabView. How can I do it? Can I connect this chassis to my PC using NI DAQmx? Is it possible?
(4,956 Views)
Hello aanodin!
cRIOs are not compatible with NI-DAQmx because they don't use the same data acquisition process as our DAQ devices. They would instead use the LabVIEW Real-Time Module and the NI-RIO driver. Since the cRIO-9066 controller's operating system is Linux Real-Time, you can deploy your C++ code directly to your target using the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition.  I would recommend reading the following articles:
White Paper on Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHR7CAO&l=en-US
White Paper on C/C++ Embedded System Design Tools:
https://www.ni.com/en/shop/linux/c-c---embedded-system-design-tools.html
Evaluation of C/C++ Development Tools for Ni Linux Real-Time, Eclipse Edition 2014:
https://www.ni.com/en/support/downloads/software-products/download.c-c---development-tools.html#3334...
I hope this helps!
Nadine H.
Applications Engineer
(4,913 Views)
Thank you, Queen_Nadine!
Does it mean that I can only run my C code on the device and there is no way to acquire any measurement data on the host computer without LabView?
(4,905 Views)
Accepted by aanodin
You could use TCP/IP to stream the data to a Windows computer and have that computer log the data or do whatever else you need.
But you might want to just get a cDAQ Chassis instead and then you can just use the DAQmx API.
GCentral
(4,894 Views)
