Multifunction DAQ
Data acquisition using cRIO-9066 and C++
Hi there!
I want to write a C++ application which would acquire data from some modules installed in cRIO-9066 chassis and this application have to work without LabView. How can I do it? Can I connect this chassis to my PC using NI DAQmx? Is it possible?
(4,955 Views)
Hello aanodin!
cRIOs are not compatible with NI-DAQmx because they don't use the same data acquisition process as our DAQ devices. They would instead use the LabVIEW Real-Time Module and the NI-RIO driver. Since the cRIO-9066 controller's operating system is Linux Real-Time, you can deploy your C++ code directly to your target using the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition.  I would recommend reading the following articles:
White Paper on Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHR7CAO&l=en-US
White Paper on C/C++ Embedded System Design Tools:
https://www.ni.com/en/shop/linux/c-c---embedded-system-design-tools.html
Evaluation of C/C++ Development Tools for Ni Linux Real-Time, Eclipse Edition 2014:
https://www.ni.com/en/support/downloads/software-products/download.c-c---development-tools.html#3334...
I hope this helps!
Nadine H.
Applications Engineer
(4,912 Views)
Thank you, Queen_Nadine!
Does it mean that I can only run my C code on the device and there is no way to acquire any measurement data on the host computer without LabView?
(4,904 Views)
Accepted by topic author aanodin
You could use TCP/IP to stream the data to a Windows computer and have that computer log the data or do whatever else you need.
But you might want to just get a cDAQ Chassis instead and then you can just use the DAQmx API.
GCentral
(4,893 Views)
