08-18-2016 12:34 AM
Hello. I'm using "cDAQ-9178" and "NI 9215" and "NI 9402" are added on.
However, when I run a Labview code, "Error-201003" occurs.
Device cannot be accessed. Possible causes:
Device is no longer present in the system / Device is not powered /
Device is powered, but was temporarily without power / Device is damaged
(Error is shown like the 1st and the 2nd figures below.)
(Sheme of the logic is in the figure below.)
Thank you.
08-18-2016 01:41 AM
Hi keuntae,
did you try resetting the device or running a self test?
08-18-2016 05:27 AM
Yes. I'm afraid that I already did that.
08-18-2016 06:37 AM
And what happens? Do you get the same error?
08-18-2016 04:01 PM
I could be something with the driver
check this:
Error 201003 at Test Panel in MAX or While Running DAQ Assistant
http://digital.ni.com/public.nsf/allkb/5413F392D88326148625746B006745C5
In this forum, they talk about the same error:
Spontaneou
http://forums.ni.com/t5/SignalExpress/Spontaneous-Error-Code-201003-for-PCI-DAQ-Setup/td-p/830707
08-18-2016 04:02 PM
make sure DAQmx version you got is compatible with the Labview you are using, check the readme file of that version of the driver
