07-18-2009 02:53 AM
Sir,
I am using PCI 6220. I am giving an external 2KHz pulse to DAQ pin no 0.0 from another source. I am able to receive the signal. I am trying to get the digital output from DAQ pin no P0.1. When I view the signal using CRO I am not getting the 2KHz clock. Instead I am getting aperiodic signal from the same. CAn anyone help me why this occurs and I cannot understand why there is a mismatch between the two. I would like to build my application using this technique.
Thanks in advance.
07-18-2009 09:54 AM
07-20-2009 02:36 AM
I have attached my VI.Whether my VI is correct or wrong. Please provide me one example VI for this issue.
07-20-2009 09:44 AM
Try setting the mode to continuous and set the number of samples equal to the sample rate.
There is an example called Cont Read Dig Chan-Ext Clk that you can try as well.
