Fluke PS410 Simulator with SCB-68 Connection
Hi..
*Iam Using the SCB-68 Board with PCI/PXI 6225 Card for data Acquisition.
Motive:
1) I wish to Acquire the RA Signal,LA Signal and RL Signal and implement the following in LabView
        Lead II = LA - RA
                                                              Actual Lead II = Lead II - RL
 2) There is a High Level Connector on the Simulator at which the Lead II Signal is available so i connected an Oscilloscope with Negative pin on the RL pin and the Signal was Correct So all i have to do is to Acquire the three Signals now.
Problem:
As there is no reference for the RA , LA and RL Signals How can i Acuquire them..??
I want to know the Switch Settings and any Signal Conditioning that i might need since the signals are in the range of MiliVolts,Configurations that should be done in the NI Max Explorer and the Acquiring Option i.e RSE,NSRE,Diff etc....
Hamza Khan
(3,694 Views)
Hi Hamza Khan,
I'm attaching a link below to the M Series User Manual.  Chapter 4 on Analog Input has good descriptions of how to wire up various signal sources for data acquisition.  I'm also including a link to a white paper on general field wiring considerations for analog signals.
http://www.ni.com/pdf/manuals/371022k.pdf
Field Wiring and Noise Considerations for Analog Signals
http://www.ni.com/white-paper/3344/en
Josh B
Applications Engineer
(3,659 Views)
