02-08-2007 08:04 PM
I have connected the inner core of the BNC cable to the pin 68 and the external part to the pin directly below it 34. I have also pushed up the S5 and S4 switches to the upper position. Do I need to do anything else?
When I am in MAX I go into
Driver Interface -- NI DAQmx device -- NI PCI -6052E: "Dev1" Test panel and the analog is 0.214 and fluctuates slightly but even with the signal conditioner power switched on or off it is the same.
Also
Driver Interface -- Traditional NI DAQ(legacy) device -- PCI -6052E(Device1) -- test panel -- the analog input is 0.215 and again fluctuates slightly but even with the signal conditioner power switched on or off it is the same.
What do I need to do?
02-09-2007 01:40 PM - edited 02-09-2007 01:40 PM
Message Edited by Jesse O on 02-09-2007 01:40 PM
