LABVIEW DAQ Signal Generator trigger
Synchronous trigger between data acquisition card and signal generator;
The DAQ starts collecting when it receives the trigger pulse;
(705 Views)
Depends on DAQ model and Signal Generator model. May be it is possible, may be not. Need more information to guide you.
Santhosh
Soliton Technologies
(697 Views)
I want to use the data acquisition to collect the signal in the signal generator, and realize the timing of the signal generator to generate and stop the signal by means of external trigger
(686 Views)
Okay, but you've not shared what model of DAQ and what model of signal generator. Triggering is an hardware feature and must be supported by the actual DAQ and Signal Generator you are using.
Santhosh
(680 Views)
