08-29-2014 11:01 AM
Hi everyone,
I recently bought a multifunction DAQ USB-6218 and installed all the software for it (namely, nidaqmxbase and nikal).
When I connect the device to my computer, I don't see the power/activity light blinking like my other DAQ USB-6008.
tog@home ~ $ lsusb Bus 002 Device 003: ID 8086:0189 Intel Corp. Bus 002 Device 008: ID 18d1:4ee2 Google Inc. Nexus 4 (debug) Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 003 Device 008: ID 3923:7269 National Instruments Corp. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 005: ID 1bcf:2b81 Sunplus Innovation Technology Inc. Bus 001 Device 004: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsdaq
tog@home ~ $ lsdaq -------------------------------- Detecting National Instruments DAQ Devices Found the following DAQ Devices: --------------------------------
Running sudo FWUpdate doesn't list any devices.
Thanks in advance!
09-02-2014 09:22 AM
Bump. There must be some log file or some firmware update procedure that I'm missing. Any help would be really appreciated!
09-02-2014 03:39 PM
Hello tog000,
I have a couple questions that will help clarify your setup so that I can help troubleshoot your hardware connection.
Thank you for the additional information!
09-05-2014 10:01 AM
Thank you Earl. Sorry for the delay in replying.
The DAQ works just fine in OpenSUSE, but I have certain system components that I cannot port. The surprising part is that the cheaper USB DAQ works just fine, but this one (6218) doesn't.
Thanks in advance!
09-08-2014 05:02 PM
Hello tog000,
Has the device worked properly in any other computer? Has it worked before?
Ernesto
09-08-2014 05:46 PM
I have a computer running OpenSUSE 32bit and the device works there.
I verified that the nikal module is loaded in Ubuntu, but there are certainly more NI modules being loaded into the OpenSUSE kernel that I don't see in the Ubuntu kernel. Unfortunately I haven't been able to find which package they come from and verify they are being installed.
Oddly enough, the DAQ USB-6008 works just fine in Ubuntu with the NIKAL driver.
Thanks!
09-09-2014 01:52 PM
Hello tog000,
Could you please tell me which National Instruments drivers do you have installed in the computer with openSUSE? Also the versions of the installed drivers over there.
Then I will also like to know what are the drivers and the their versions, that are installed in the computer with Ubuntu.
Regards.
Ernesto
09-10-2014 09:28 AM
Hi Ernesto,
I will get you this information first thing tomorrow.
Thanks for all your help!
09-11-2014 08:12 AM
Hi Ernesto,
I tried to list packages in OpenSUSE, but I didn't have luck with that, so instead I ran what I had run before:
lsmod | grep "ni"
On Ubuntu:
nikal 109014 0 ghash_clmulni_intel 13259 0 aesni_intel 55624 2 aes_x86_64 17131 1 aesni_intel lrw 13286 1 aesni_intel glue_helper 13990 1 aesni_intel ablk_helper 13597 1 aesni_intel cryptd 20359 3 ghash_clmulni_intel,aesni_intel,ablk_helper
On OpenSUSE:
nimxdfk 495736 1 nipxirmk 206562 1 nidimk 328434 2 nipxirmk nimdbgk 381773 3 nimxdfk,nipxirmk niorbk 100919 4 nimxdfk,nipxirmk,nidimk,nimdbgk nipalk 1222196 8 NiViPciK,nimxdfk,nipxirmk,nidimk,nimdbgk,niorbk nikal 101545 2 nipxirmk,nipalk aesni_intel 18156 0 ablk_helper 13357 1 aesni_intel lrw 13057 1 aesni_intel aes_i586 16995 1 aesni_intel xts 12749 1 aesni_intelThere is a big difference in modules, but I can't seem to find or install them under Ubuntu. Thanks in advance!
09-11-2014
09:43 AM
- last edited on
08-09-2024
12:55 PM
by
Content Cleaner
Hello Tog000,
I checked and it seems that Ubuntu is not one of the National Instruments supported distributions.
But I was thinking the following links may have useful information for you to find help:
More specifically in:
https://forums.ni.com/t5/Linux-Users/bd-p/5097
and the next link says which distributions are supported.
What Linux Distributions Do National Instruments Drivers and Software Support?
https://www.ni.com/en/shop/software-portfolio/platform-roadmap.html
Good luck with your application.
Ernesto
