02-09-2016 03:56 PM
I am trying to measure a period less than 392ns and I get the error :
Error -200141 occurred at DAQmx Wait Until Don.vi:3580001
Possible reason(s):
Data was overwritten before it could be read by the system.
If Data Transfer Mechanism is Interrupts, try using DMA or USB Bulk. Otherwise, divide the input signal before taking measurement.
Task Name: _unnamedTask<E85>
I have attached a screenshot of my VI
02-10-2016 09:39 AM
Hi ADI_Tony,
What hardware are you currently using to take this measurement? Depending on the hardware you are using this may be the issue.
02-10-2016 10:32 AM
I am using the PXI-6289. It has an 80MHz counter which should still be able to "count" measure a period this fast.
02-11-2016 05:11 PM
Hi ADI_Tony,
What do you have your Number of Samples control set to? According to the specification sheet for the PXI-6289, the FIFO for the Counter is only 2 samples.
NI 6289
http://www.ni.com/pdf/manuals/375222b.pdf
If your number of samples, was greater than 2 it would make sense that you received the buffer overflow. Have you looked at the "Counter-Read Pulse Width and Frequency (Continous)" example in the NI Example Finder. Are you able to run this code without getting an error?
So, if there are more
02-12-2016 04:41 PM
I have been taking 500 samples. For slower frequencies there is not problem. The only time I have an issue is trying to measure a period <392ns. Greater than 392ns works no problem
02-15-2016 05:23 PM
Hi ADI_Tony,
From the screenshot in your original post, it looks like you are using only 1 counter, which is fine for low frequencies. Have you tried using a two counter method that works better for high frequency measurements? An example for which can be found below.
https://decibel.ni.com/content/docs/DOC-11424
Let me know if this works!
02-16-2016 09:18 AM
Or use some external FF -> frequency divider
But the two counter method (see excamples) should do it.
02-16-2016 03:59 PM
I used the 2 counter method and was able to measure period down to 112ns now. Works great. Will have to play with the divisor option as well to see how that works. Thank you for the help!
