04-30-2015 09:48 PM
Hi there,
I have a cDAQ-9178 with NI9207 (AI), NI9265 (AO), 2* NI9213 (TC), NI9375 (DIO) installed. Everything was working fine.
We then added additional signals:
- 1 new AO to one new NI9265
- 1 new DI to existing NI9375
- 4 new TCs to existing NI9213.
Since the additions, the new TC signals work fine, the existing AI, AO, TC signals all work fine. But I cannot get the new DI and new AO signals to work. Is there a specific step in the set up that needs to be done? I did not set up the original system so I'm unfamiliar with set up requirements.
Cheers.
05-01-2015 07:28 AM
05-03-2015 09:08 PM
If you're specifically referring to the software aspect of the new connections - I just changed in the settings in the VIs.
I've attached screenshots of the old and new VIs. In the "Old1.png" and "New1.png" the selected channels changed with the new connections. Again the thermocouple ones work fine. But not the digital input.
In "New2.png" the entire connection for the 1 channel analogue output is new. No luck on this new connection.
05-04-2015 08:23 PM
We got it to work! There were mistakes in the wiring.
