Thanks to Andrew S for the very helpful answer to my last question.
Regarding analog inputs on simulated devices, I get the impression the simulated input is always a sine wave with an amplitude set to the maximum Signal Input range as set in MAX. But I am confused about what the frequency of this sine wave is supposed to be.
Using the DAQmx VIs, if I read 1000 samples at a rate of 10 samples per second, I seem to capture a complete cycle in 100s. If I read 1000 samples at a rate of 1000 samples per second, I seem to capture a complete cycle in 1 second. Hence the frequency of the sine wave went up, right? Otherwise in one of the two cases above I should have captured less than a complete cycle. Am I understanding this correctly? Thanks...
