09-30-2009 02:44 AM
What is the size of the "shielding screws" for the cover of the SCB-68
(I've lost the original ones and need to replace them.)
10-01-2009 04:25 AM
These screws have a 2.5mm diameter. (same as the connector screws) and are about 4mm long.
Rémi M.
National Instruments France
>> Les présentations NIDays 2010 déjà disponibles au téléchargement !
10-01-2009 04:44 AM
Thanks for your response.
So if the diameter is about 2.5 mm, I'm assuming they are a #3 screw? Can you tell me if it is a coarse or fine thread (#3-48 or #3-56)?
A mechanical engineer at NI should be able to pull up a drawing for the box...
10-01-2009
06:07 AM
- last edited on
10-01-2009
11:19 AM
by
Support
Please find attached some datasheets and drawing of the SCB-68.
You should be able to find the details you need based on these docs.
Have a nice day,
Rémi M.
10-01-2009 08:21 AM
10-01-2009 11:11 AM
