Multifunction DAQ
Size of Shielding screws for SCB-68
What is the size of the "shielding screws" for the cover of the SCB-68
(I've lost the original ones and need to replace them.)
(3,414 Views)
These screws have a 2.5mm  diameter. (same as the connector screws) and are about 4mm long.
(3,395 Views)
Thanks for your response.
So if the diameter is about 2.5 mm, I'm assuming they are a #3 screw? Can you tell me if it is a coarse or fine thread (#3-48 or #3-56)?
A mechanical engineer at NI should be able to pull up a drawing for the box...
(3,391 Views)
Accepted by bnall
Please find attached some datasheets and drawing of the SCB-68.
You should be able to find the details you need based on these docs.
Have a nice day,
Message Edited by Support on 10-01-2009 11:19 AM
(3,388 Views)
Thank you. This is exactly the information I needed.
(3,382 Views)
For those who need this in the future, the screw is a 4-40 x 1/4,Phillips Head, SS, w/ integrated washer.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,358 Views)
