Modular Data Acquisition
High-Performance Test
07-15-2015 09:32 AM
I need to create a time controlled boolean.
For example a digital line is set to False. I'd like to change to True status for a certain amount of time (e.g. 150ms).
Is it possible with PXI 6251?
07-16-2015 02:49 AM
yes you can. Set a buffered digital output task like "Digital - Finit Output.vi" example.
You can use an external clock, generate it throught counter output or use ananog in/out sample clock.
Thanks!
We'll be in touch soon!
