Multifunction DAQ
Time Controlled digital line PXI-6251
I need to create a time controlled boolean.
For example a digital line is set to False. I'd like to change to True status for a certain amount of time (e.g. 150ms).
Is it possible with PXI 6251?
(4,149 Views)
Accepted by aethon
yes you can. Set a buffered digital output task like "Digital - Finit Output.vi" example.
You can use an external clock, generate it throught counter output or use ananog in/out sample clock.
(4,100 Views)
