08-19-2009 10:05 AM
I have a PCI-6030E. When I look at its digital output at port0/line0, I see 1V instead of 5V when it's 'high'. It read 0V when 'low'.
Any ideas?
Amit
Solved! Go to Solution.
08-19-2009 01:55 PM
08-20-2009 12:35 AM
I am looking at it with a simple voltmeter, which should have a very high impedance by definition.
Amit
08-20-2009 08:48 AM
Hi Amit,
If you look at other channels, do you see 1 V as well? I would make sure that other channels behave the same way. Also, I would make sure that you are using Test Panels in Measurement and Automation Explorer. If you suspect that your card is malfunctioning, you can go to ni.com/ask and create a service request. Make sure to change the question type to Returning hardware for repair/replacement/calibration. Then call 1-866-275-6964 with that service request number to send in your board for repair.
08-20-2009 09:06 AM - edited 08-20-2009 09:09 AM
